There is a write up on a really good swap in the "Search" section...
Seriously though, no not really. The best thing would be to swap the trans for a 5 speed manual e153. The engine you have (3vz-fe) is actually the best for handeling high boost numbers. If ya want an engine that will be easier to add the handfull of parts available then you could consider the 1mz fe, which is practically the same motor just lighter with with slightly different numbers. It can't handle boost quite as well though. More info about swaps can be had with a search of this forum...have fun
