Power Door Lock Only Locks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2011, 12:39 PM   #1 (permalink)
View Pamtoy's Photo Gallery
The power door lock switch on our 97 Camry will only the lock the doors.It will not unlock them.
Locking and locking the doors with the key in the driver's door operates all door locks fine;they both lock and unlock.
Can I conclude the problem is with the door lock switch itself? Anyway to test it?
Thanks
Pamtoy is offline   Reply With Quote
Old 12-20-2011, 05:14 PM   #2 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
If the passenger side works, replace the driver side switch.
deadrx7conv is offline   Reply With Quote
Old 02-02-2012, 04:20 PM   #3 (permalink)
checking continuity
Turns out a connection must have been loose as I removed the assembly and put it back in place. Now it works. But I'm still curious in case there is a future problem;is there a way to check continuity on the contacts? I have no idea as to where one would place the leads.
thanks
