bleeding my clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2011, 10:04 AM   #1 (permalink)
View totc's Photo Gallery
bleeding my clutch
I am going to bleed my brakes and my clutch this weekend. I know with the brakes to start at the corner furthest from the master cylinder and work my way to the closest corner. My specific question is, is there any thing special about bleeding my clutch? I've never had to bleed one before, and wish to cover my bases. Thanks.
totc is offline   Reply With Quote
Old 12-21-2011, 11:01 AM   #2 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
nothing special. if you have two people, this is how you do it:
person inside press clutch pedal down
person outside opens bleeder
person outside closes bleeder
person inside pulls clutch pedal up
repeat over and over and over
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 12-22-2011, 02:23 AM   #3 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
I tried the above method the other day and the clutch pedal 'stuck' to the floor. It sprung back if I pulled on it, but I lost clutch operation for several minutes i.e. Pedal would either be to the floor or inline with the other pedals. No in-between and no resistance like usual. I hand 'pumped' it a few times, but wouldn't suck fluid from the reservoir any faster.
Doesn't seem to want to bleed like a brake system.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 12-24-2011, 12:10 PM   #4 (permalink)
camrtm3's Avatar
Gameroom cash: $102305
View camrtm3's Photo Gallery
^ you have to make sure that there is no air in the line. if you get any air in the line it will do exactly what you are describing. This includes if you pull the pedal back up with out closing the bleed valve. you will just suck air back in. it happens. or if a line is not connected properly.
if its either on the flood or up and there is no in between, then there system is still open somewhere.
2009 EX-L V6 6Spd MT w/Nav (stock for now)
1996 XLE V6 Camry, KSport GT Pro 9/7, TRD RSB, E153 5spd conversion, Gen 3 front end conversion, OBX Headers, Megan Cat Back, TRD M62 Supercharger
Supercharger whine > ex girlfriends whine
http://www.cardomain.com/ride/3329124
camrtm3 is offline   Reply With Quote
Old 12-24-2011, 04:52 PM   #5 (permalink)
セクシーの定義
My clutch still works though :S. I left it for a few minutes, saw the reservoir dropped a bit and had feel in the clutch pedal. I can shift into every gear including reverse.
Camry history:
