Spark Plug Coil Connector - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-21-2011, 06:08 PM   #1 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
I just replaced the valve cover gaskets on my 1MZFE and it wasn't that hard thanks to all of the DIY'S from this forum. I did have a problem with the plastic coil connectors.
When I reassembled everything back together and started the engine the CEL threw a P1300 code indicating a coil or spark problem. I checked the connectors on the front right side 2,4,and 6 and although they were cracked the pins were engaged and making contact with the coil. Now I had to remove the intake manifold again to check the other 3 coils. Sure enough the #3 connector was not making solid contact with the coil. The connector was flush with the coil but I noticed that the two wires and rubber seals were too far out of the plastic housing. I removed the connector and had to pull the wires thru the connector and manually attach them onto the pins of the coil. I sealed everything with some RTV and everything is now fine. If this did not fix the problem the only alternative other than a new wiring harness was to check with a local wrecker to see if I could find some connectors. These connectors are very brittle and fragile so be careful when disconnecting and reattaching to the coil.
92 Corolla 4AFE, 94 Camry LE V6
91boz is offline   Reply With Quote
