window motor, switch , regulator
have a 96 camry
the driver side window use to go down but not up
now it does not do either
the motor sounds like it works but the window does not move
i unpluged the motor, used a voltmeter to measure dc volts inside the plug (male i think) (the plug that leads to the switch not the motor), i got around 12.6 volts while pushing the window up button, and window down button
however, i am confused because when the plug is connected the window motor makes the rrrrrrrrrrrrrrrrrrrrr noise the known good ones make. is this motor bad? does anyone know how to test the motor itself?
i have not greased anything yet.
