Handbrake does not engage (falls down, releases itself) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2011, 12:59 PM   #1 (permalink)
View Reit38's Photo Gallery
after replacing the o2 sensor on my car i lowered it back down and reset the code to find the abs light flashing and no handbrake at all. how do i go about tracking down this problem
Reit38 is offline   Reply With Quote
Old 12-22-2011, 02:17 PM   #2 (permalink)
View Pandalizer's Photo Gallery
handbrake cable snapped or came loose somewhere? Check to see if its still attached to handbrake. Then check to see if its still connected to rear brakes?
_______________________
1998 Toyota Camry | 3.0L 1mz-fe
5900k Headlights | Tockico Struts and Springs
18" Enkei NT03 Racing Series | Metallic Candy Blue Paint
Glow Gauges | Kenwood Deck
x4 Infinity 500 Watt Speakers | 2x 500w Pioneer Subwoofers | N1 Catback
Pandalizer is offline   Reply With Quote
Old 12-22-2011, 02:36 PM   #3 (permalink)
That's what I'm thinking but don't know how it would of got meeesed up. I know it was fine prior to jacking it up, and I set it down slow. I'm getting ready to tear out center console to checkfor broken cable.
Guess I don't really know what to look for at rear tire
Old 12-22-2011, 04:11 PM   #4 (permalink)
ended up being the dogleg that catches the "gears" was gummed up. little lube and its working fine again and the abs light is off
still dont how this would have tripped the light?
Old 12-22-2011, 05:05 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If the handle falls down by itself then check the cam gears on the hand lever. It should be quite visible once you removed the console.
