98 Camry variable rpm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2011, 01:05 PM   #1 (permalink)
View mkv_camry's Photo Gallery
Yesterday, when i started the camry after 20 mins break, the car was showing variable rpm and was making noise like increase engine noise, decrease engine noise. there was slight vibration too.
the rpm was around 750-900 rpm and was continuously varying in that range.
what could it be?
one of the mechanics said, timing belt may need a change soon since its loose. could it be because of this? please advice
thank you
mkv_camry is offline   Reply With Quote
Old 12-22-2011, 05:46 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
So its idle RPM is bouncing between 750 & 900 RPM?... surging up and down? No, that's not typically caused by a timing belt. Most of the time, it's because the IAC (Idle Air Control) valve needs to be cleaned.
Does it have a V6 or 4 cylinder engine? If it's the 4 cyl, here's one DIY thread showing how to remove/clean it. And here's another.
BMR is offline   Reply With Quote
Old 12-22-2011, 06:13 PM   #3 (permalink)
thanks for the info. it is a 4 cylinder. 2.2 LE.
I will see if i can DIY. Else will have to get it done outside.
thank you
