Originally Posted by rgdeja
Yes, the both ground wires are connected to Air Intake Chamber.
Actually three wires, two one the side and one in the back.
I am going to check again to see if I missed anything. Will update...
If the two large set of wires in the wiring loom are connected, along with the single small one, then trace the small thin one back to be sure it's securely clipped into the connector right under the dog bone, that grounds to the body right above the strut tower.
There are two ground wires in connectors there. Be sure they are both pushed in tight. Wouldn't hurt to put some dielectric grease in the connectors if you have any.
If all that is OK, then I'd remove all the bolted connections, clean them up with carb cleaner, and a light scuffing with sandpaper to insure that there is a good contact after they are bolted back to the ACIS.
If none of this solves the problem, then I'm fresh out of ideas.
