Originally Posted by ricamryman
When my car had 106 K miles I had the plugs changed out with new wires,cap,& rotor! I am at 147K miles now. When do I need to change the plugs again? Its a 1993 3VZFE V6 engine. ......
IIRC, the manual recommends 100k miles intervals, assuming platinum plugs are used. So you're probably good for a while yet. If you don't know what plugs are in it, pull one out of the front bank to check; they're easy-peasy to get out.
