The $500-$600 quote includes the parts?... If yes, what, exactly? If it includes everything, that's not too bad. Everything = struts, upper mounts, bearings, and lower & upper spring insulators. You'll get all sorts of opinions on brands to use. I put KYB GR2's on my Avalon a while back, and like them alot. Close to stock ride quality.
As for where to go, my only advice is where not to go. And that would be dealerships & chain stores like Midas, Firestone & such. Go to a locally owned & operated shop. Less overhead = better prices.
