I can't find a DIY thread for it, but it's pretty straightforward.
1) remove plug wires or remove distributor cap with wires intact.
2) remove bolts at base of distributor (I think there's two, maybe three)
3) remove distributor & replace o-ring
4) reinstall disty
5) set ignition timing
Some would tell you that before removing it, to mark the distributor's angular position so you can get it back into the same position when it's reinstalled, and not have to check/set ignition timing. I dunno if that's possible to do accurately enough, if you care that it's off a couple of degrees.
