Originally Posted by deadrx7conv
The valve body should NEVER need cleaning out.
Change the ATF.
Exchange the fluid yourself using the cooler line method. Avoid shops that use any type of solvent or cleaning solution.
what he said^^^^^ if you drop the pan and change the filter it takes about 1.5 hours. if you don't drop the pan it takes about 45 minutes
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
