I've got a 1993 Camry 4 cyl, auto, and both back up / reverse lights stopped working. I don't think anyone has posted my particular problem -- the "R" on the dashboard indicator works fine, it's only the bulbs that are out. I'm aware of the fix with the Park Neutral Position Switch (PNP switch) but since the "R" light is working I'm thinking I might be barking up the wrong tree.
Also, there is no dashboard light that indicates a burn-out bulb and the check engine light is not on. I have already tried the following:
- checked all fuses (in particular, the "gauge" fuse)
- checked the bulbs
- checked for a wiring short in the trunk
- adjusted the little screw in the shifter assembly as discussed at this thread:
Reverse Light switch problem!
I don't have a meter so when I say I have checked the trunk for a wiring short, that means I wiggled the wires around and nothing changed.
I've never used the ECM but wondering if I should try to see if a code flashes...
Any thoughts are greatly appreciated.
Thanks,
ND
