5sfe pistons....
What are my choices for aftermarket pistons.. Isnt stock bore 87.1mm? Everything i found says to use the 3sgte head... and the bore states either 86.5 or 87.5mm... I rather not have to bore the block out.. Im not sure if i bent a valve or cracked a piston untill i rip it apart.. I did compression test.. got nada from cylinder 3... I did a leakdown.... All seems to be leaking into the crankcase, so I think i demolished a piston. So what are my options for aftermarket pistons.. and yes it will be turbo'd.
