First read through the DIY section and see if that's something you (and maybe a mechanically inclined friend) can handle. You can make special pulley holding tools inexpensively from Home Depot parts.
You can buy OEM parts from eBay (Aircabinman) or 30% off MSRP from TN sponsors like ToyotaPartsMan. Here is a list of what you should consider changing that I compiled from rockauto.com. You can also talk to shops to see if they'll use the parts you bring.
GATES K030295 Micro-V AT Power Steering Belt $5.14
GATES K050435 Micro-V AT Alt/AC Belt $14.10
FEL-PRO TCS45920 Crankshaft Front Seal Set $5.10
FEL-PRO TCS45641 Camshaft Front Seal $3.66
NATIONAL 221820 Polyacrylate Oil Pump Shaft Seal $2.86
GATES TCK199 (1 Belt, 1 Tensioner, 1 Idler) Timing Belt Component Kit $52.89
STANT 48278 180° w/Jiggle Pin OE Type Thermostat $10.94
AISIN WPT010A Water pump w/o housing $30.79
FEL-PRO VS50304R1 Valve Cover Gasket Set w/Spark plug tube seals $18.26
Subtotal $143.74
Shipping about $20
Originally Posted by rebuy
So I am past due for all belts to be changed. Last time timing belts changed was 200K miles ago and don't know if water pump was changed. This seems to be a part that fails after a belt change. Should I change the water pump?
Do I need one without a cover? What about the oil pump? what is the life expectancy of the oil pump? Just replace seals or what?
What brands do I use? Planning on going to a Toyota dealer to get this done.
I figure they will do the work correctly.
Are they gonna make me buy the parts from them?
I'm on a tight budget and need some help.
Thanks.
