There is a spaghetti O-ring gasket that should be replaced, it goes between the oil pump itself and the oil pump housing, easy to replace. There is also a shaft seal, they often leak as well. To replace this, you have to remove the oil pump, then remove the gear to get to it. The shaft itself has a habit of developing a groove in it, if so, then the shaft will have to be replaced. An alternative is to replace the entire pump, they go for about $75.
The oil pump itself can easily last the life of the engine, assuming you take care of the above issues.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
