Brake pedal alternates between firm and soft - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2011, 03:47 PM   #1 (permalink)
Gameroom cash: $167900
View capnblinski's Photo Gallery
I'm having an issue with my brake pedal modulation. On wet rainy days the pedal is nice and firm, but once the weather clears the pedal becomes mushier. Has anyone had this problem, and if so, what would it take to fix?
2000 Camry LE 5sfe
172xxx miles
capnblinski is offline   Reply With Quote
Old 12-29-2011, 04:32 PM   #2 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
Hmm...lets start out with...Have you replaced the brake fluid? If yes, how long ago? What color is the fluid now?
95 Camry LE I4 195k
bdy0003 is offline   Reply With Quote
Old 12-29-2011, 04:57 PM   #3 (permalink)
Haven't ever replaced the brake fluid. I've had the car nearly two years (it was well maintained) and the fluid in the reservoir looks clear/very slightly yellowish.
Old 12-29-2011, 06:17 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Humid air can make your brakes work better, it improves contact/friction between the pad and rotor, making the pedal feel better (because it requires less pedal force). How do your pads look, brand of pad if known. What about the rotor? What is the condition of the drum/shoes?
To fix the problem permanently, replace the pads and rotors if needed, inspect and/or replace the rear brakes, and flush the fluid.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 12-29-2011, 08:14 PM   #5 (permalink)
Over the years I have noticed small differences in pedal feel with humid/non-humid conditions -- the present mushiness is just more pronounced.
The brakes are very good when the pedal feels firm -- there is no grabbing or pulsation of the pedal like you get with bad rotors. They are the best brakes I have had so far on a car -- seeing that it is the most modern car I've had -- and the previous one-owner took good care. The pads are about halfway and the same with the rear shoes. Don't know the brand of pads but through researching here on TN, I've been planning on the Akebono's when the time comes for pad replacement.
So I will do a flush of the brake system also -- there must be a DIY here somewhere, and then get back to yin's with the results.
Old 12-29-2011, 08:29 PM   #6 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
Make yourself a PowerBleeder. Thread is here.
PowerBleeder - Bleed your brakes the easy way. Many pics.
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is online now   Reply With Quote
Old 12-29-2011, 10:56 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
mushy brakes feeling can be dozen of things, start with the life savers first (new pads and resurface rotors, flush the brake fluid with any Low Moisture Activity formula like Castrol or Valvoline) then think of testing other items.
your problem *could* be related to early sign of failing Master Cylinder cup seal (there is two of them on the piston).
other than that, old rubber brakes lines at calipers can be calling for replacement. I am actually one of those people who replaced MC (old one was rusted), both front calipers with "new" remanufactured Cardone (old ones had sticky pistons), installed new pads and resurfaced rotors all around, replaced faulty ABS with burned out computer (used a junk yard working pull) and still having the mushy brake pedal LOL
the last 2 things left in system are rubber brake lines and brake booster... and something tells me it's the rubber lines being responsible for the pedal feeling ... I'm not there yet to replace them though hehe ...
Old 12-30-2011, 12:43 AM   #8 (permalink)
71Corolla's Avatar
Properly bleeding the brakes is very important IMO. Cheapest way is to use the two person method, one pumps the pedal 2-3 times with the bleeder closed, then holds the pedal down as the other opens the valve. The valve is then closed before the pedal is released. I find this method works really well and purges the air out quickly. Another way is to use a one-way valve, I use this method, although my hack job device is starting to fail on me. I would like to get a hold of a proper bleeding system at some point it would save me a lot of time.
If you just take a hose and drop that into a jar of fluid, then you will automatically get air into the system when you open the bleeder, and pumping the pedal will not move the fluid effectively, every time you let up on the pedal, the fluid and any air will partially sucked back into the system.
Some people have mentioned that allowing the pedal/master cylinder to go all the way down to the end of the travel can be bad for it, because the rubber parts will contact an area that it never normally does, and can cause damage. I've never had this happen personally but I can understand how it could occur. A way to prevent this is to put a block of wood under the pedal to prevent full travel.
Old 12-30-2011, 11:37 AM   #9 (permalink)
Thanks guys and happy new year by the way.
That PowerBleeder is too cool! How much to make one for me? lol.
I'll post back asap on the fix - hopefully new brake fluid will be all that I need.
