grats on the mileage!!
if coolant level is dropping on its own check for leaks, spots under car, pinkish (or whatever color you use) stain around engine and such.
you could also do a cooling system pressure test (any local shop should be able to do it for you) to see if it holds the pressure ... and if it leaks it should make it easy to notice the spot, it will be squirting (if external). for checking on internal leaks it's good to have spark plugs out, it will come out of there if that's the case (hopefuly not, it means the Head Gasket is blown).
