Can I find out if timing belt was changed? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2011, 04:34 PM   #1 (permalink)
View crc13's Photo Gallery
I bought my 2001 used can I find out if the timing belt was changed by the vin number?
crc13 is offline   Reply With Quote
Old 12-31-2011, 05:08 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Maybe. If it was done at a Toyota dealership, they would be able to look it up by the VIN and see it in their records. But if it doesn't show up there, it doesn't mean it wasn't done. You could also look around under the hood for a sticker noting when it was changed, particularly on the timing belt cover. Many shops do that.
BMR is offline   Reply With Quote
Old 12-31-2011, 10:22 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
go to http://www.toyota.com/owners
register a free account and enter your car's VIN under your name. it will give you access to Service Records in Toyota system. if the timing belt was EVER changed at ANY dealer, it will be there along with everything else that was touched or inspected for problem.
The Following User Says Thank You to fenixus For This Useful Post:
Brit101 (01-03-2012)
