Mechanic just replaced my broken timing belt, and car now won't start due to "low compression."
There was an oil leak, prior to the chain breaking.
Mechanic said he had put some oil in the cylinders in case of wash out from gas as a result of trying to start it with a broken belt.
Mechanic claims the gears are alligned right so the valves aren't supposedly leaking due to that.
How else could a perfectly running engine all of a sudden lose compression from all cylinders because of a chain breaking. Does not make any sense at all.
Low compression will not inhibit starting, NO compression, but not low. If it was starting ok before the belt change then the mechanic probably installed the belt off time. What is the compression? I suspect it's zero in more than one cylinder, a sure sign the belt's not installed correctly. Is this a 4cyl'd or 6?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
The Following User Says Thank You to Stillrunning For This Useful Post:
I told my mechanic about the belt maybe being off, and he said with 30 lbs compression, it would have to be 180 degrees off. It is a four cylinder.
Well we do know somethings different. I would check my timing. Get repair manual from store and check the timing by pulling dist.cap off. Then you can follow instructions in manual to find if you are 180 off. If you can carry on this conversation you can do it. Also, i haven't looked but i bet there is a sticky on this forum to help guide you. You may not even need a repair manual. There are all kinds of diy's stickies at the top of this forum. Hope this helps some.
J.
A BLAST FROM MY PAST, MAN, THE FUN WE HAD!
The Following User Says Thank You to JimBowNut For This Useful Post:
Timing belt isn't hard to do. Your car would've been running like crap with 30 PSI compression in a 4 stroke engine. You would have no power and hard time idling. I can guarantee that the timing between crankshaft and camshaft is off causing the valves to open early.....hence, leaking the air out....leading to no compression.
Any mechanic who truly understands engine can make sense of what I'm saying....don't have to be a Toyota mechanic....although his know-how of where alignment marks are would be handy. See step 15 and 16:
You are lucky it's non-interference...and hopefully, he was smart enough to have turned the crank two full revolution before he started the engine.....and if he did this, he would've felt that the engine has no compression.
The Following User Says Thank You to toovira For This Useful Post:
timing alignment marks are off hence the problem. mechanic sucks, change him before he talks you into "repairing bent valves" now (not really possible on non-interference engine).... probably a honda guy.
The Following User Says Thank You to fenixus For This Useful Post:
