Speaker Harness for 2001 Camry XLE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2012, 11:36 AM   #1 (permalink)
cool-vibes's Avatar
View cool-vibes's Photo Gallery
4th Generation Speaker Harness for 2001 Camry XLE
I have a 2001 toyota camry xle with the amp in the glove box area. I bought a bouble din deck to replace the stock one. I am going to buy the Crutchfield bypass amp harness # 120701761to bypass the stock amp meaning i will be using the deck to power the speakers. I would like to know if the harness that i will be getting from crutchfield will be connected at the harness coming from the back of the stock deck or do you bypass the amp completely and connect it before the amp.
Here is a picture of the Harness
http://www.crutchfield.ca/Toyota_Geo.../120701761.htm
cool-vibes is offline   Reply With Quote
Old 01-02-2012, 11:50 AM   #2 (permalink)
1994 Camry V6 XLE
Bankos66's Avatar
View Bankos66's Photo Gallery
If I am not mistaking, when you put in the new head unit, it will already bypass the amp. I did the same thing with my 1994 Camry V6 XLE. The harness will connect it to the speakers and all that. I may be mistaking so hopefully you get other responses.
1994 Camry V6 XLE -- Totalled
1995 Lexus ES300
Bankos66 is online now   Reply With Quote
Old 01-02-2012, 12:46 PM   #3 (permalink)
View slavie's Photo Gallery
The is the correct harness for using your receiver's amp. However, as far as I know, you will need to extend the wires to the amp input, so to speak.
Out of curiosity, why do you not want to use the OE amp? I'm not sure how you'll be connecting the door tweeters to your deck without the factory amp, as non-amp models were never meant to handle those two extra speakers. You'll need a good wiring diagram to connect everything correctly.
slavie is offline   Reply With Quote
