Originally Posted by Pvt-Public
Just a thought, but have you searched the forum for P0401? I just did and just in the first 2 pages there are about 20 discussions on this. I would start there. Are you also having problems with the MAP?
I read all of them. I only saw one person mentioning testing their MAP sensor and all they said was "it checked within specs".
Mine checks voltage from PCM at 4.97 volts between pin 1 and 3. This is within specs as book says 4.5 - 5.5 volts is normal.
I back-probed pin 1 and 2 and voltage checks 1.5 volts with 3 in HG vacuum, and goes to 3.2 volts at 18 in HG. My repair manual says voltage should be .3 to .5 volts at 3 in HG and go to 2.1 volts at 19.7 in HG, so is this out of spec?
At 200 bucks for a new Map, I would like to be sure this is a problem before replacing.
