Unable to pump gas in Toyota Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2012, 06:22 PM   #1 (permalink)
View Pmiller's Photo Gallery
I have a 1999 Toyota Camry that only allows me to pump 2.00 dollars at a time before the pump either shuts off or gas starts coming out of the vent. I think its the check valve in the throat of the gas tank.....any suggestions...? If it is the check valve, is it possible to replace it without replacing the whole gas tank? Thanks for any suggestions!
Pmiller is offline   Reply With Quote
Old 01-03-2012, 11:58 PM   #2 (permalink)
View LostSouthernStar's Photo Gallery
I think you may be suffering from vapor lock. If not that, then there is aserious malfunction with the cutoff switch in the fuel tank.
Hope this helps!
Anymore questions, feel do not hesitate to ask me
2001 Toyota Camry 2.2L-I4, automatic transmission with 157,000 miles.
LostSouthernStar is offline   Reply With Quote
Old 01-04-2012, 09:16 AM   #3 (permalink)
View Leinad's Photo Gallery
Check this first...had the same problem on a 1998
Problems filling up at the pump...
Leinad is offline   Reply With Quote
