ABS light on, Air Bag light on .... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2012, 07:39 PM   #1 (permalink)
View jonchanson's Photo Gallery
USA ABS light on, Air Bag light on ....
My wife was driving home in her 1999 Camry and the ABS light came on. A few seconds (or minutes) the Air bag light came on and when she attempted to turn the radio on it would not work either. Any ideas? Fuse? bad/loose wire or ???
jonchanson is offline   Reply With Quote
Old 01-03-2012, 07:51 PM   #2 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
Yes. Have you checked your own suggestions, including grounds?
TedL is offline   Reply With Quote
Old 01-03-2012, 07:55 PM   #3 (permalink)
Haven't tried anything yet I'm still at work. Just trying to figure out what I should start looking for when I get home.
Old 01-04-2012, 12:02 AM   #4 (permalink)
View LostSouthernStar's Photo Gallery
Check all of your fuses and your OBDII codes to see if anything is pending....if it's pending then it will not cause the check engine light to illuminate just yet.
Also, check your ABS control module and brake lines for any wear and defects from heat, corrosion, etc.
Hope this helps my friend!
-LSS
2001 Toyota Camry 2.2L-I4, automatic transmission with 157,000 miles.
LostSouthernStar is offline   Reply With Quote
