Originally Posted by 2011gt
The o2 sensor is stuck on the back header of the engine. I need to replace it because my cel is on. If I try and put gorilla torque on it will the threads be damaged on the exhaust manifold? How would I repair this without removing the exhaust? Can I just thread the o2 sensor on the few remaining threads and put some tack welds on it?
If I just mess up the threads does anybody also know what size tap I will need to Chase the threads?
dont' use any oxygen sensor socket, it will round the bolt if it is really stuck.
instead, get a portable yellow bottle propane torch to heat up the exhaust area where the oxygen sensor goes in, not the oxygen sensor itself, heat it to cherry red, and use the good quality 22mm or 7/8 inch 6 point close ended wrench, discnnect the electric wire harness, it should fit through the wrench hole, always works for me.
