What is proper torque for v.c. For 5sfe ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2012, 05:47 PM   #1 (permalink)
RIBMIESTER
JimBowNut's Avatar
Gameroom cash: $134901
View JimBowNut's Photo Gallery
Hey guys,
can somebody look up on service manual the torque spec for valve cover on 4th gen 5sfe 4cyl camry ?
Don't have the fsm right now...
Thanks a bunch !!!
Jim
A BLAST FROM MY PAST, MAN, THE FUN WE HAD!
JimBowNut is offline   Reply With Quote
Old 01-06-2012, 09:07 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
17ft-lbs
The Following User Says Thank You to fenixus For This Useful Post:
JimBowNut (01-06-2012)
Old 01-06-2012, 09:20 PM   #3 (permalink)
camrynoob's Avatar
View camrynoob's Photo Gallery
My haynes manual says something like 33 ft-lbs, but someone on this forum said that a revised toyota spec is 17 ft-lbs, and that is what I used when I changed the v.c. gasket last, and haven't had any problems. Someone else said to check / re-torque a few days after, and so I did that as well.
1997 Toyota Camry CE (5S-FE, 2.2L, Manual)
camrynoob is offline   Reply With Quote
The Following User Says Thank You to camrynoob For This Useful Post:
JimBowNut (01-07-2012)
Old 01-07-2012, 01:51 AM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
33 lb/ft is for the old valve cover gasket. I guess even that didn't work. The new material specs 17 lb/ft.
But re-torque after 30 minutes and periodically check it. This design isn't the best and it comes loose often.
The Following User Says Thank You to JohnGD For This Useful Post:
Old 01-07-2012, 10:27 AM   #5 (permalink)
RIBMIESTER
JimBowNut's Avatar
Thank You to all you guys.
Didn't have my FSM yesterday.
