93 V6 doesnt start after hot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2012, 07:36 PM   #1 (permalink)
View B_manne's Photo Gallery
93 V6 doesnt start
So here is my issue. The car has 230,000 miles on her, and I just changed the oil.
Lately I have replaced all wires, spark plugs and distributor and coil.
I have the water pump and timing stuff ready to change i have just been holding off because i thought I might have been the issue.
What happens is when i've been driving the car for around the town doing errands it is hot and doesn't want to crank over.
However when It does run it has no low end power but does get going in the higher rpms, but still doesn't feel like it has full power.
I was thinking Coolant Temp Sensor, or my dad was thinking it might be the fuel pump.
Any ideas guys?
B_manne is offline   Reply With Quote
Old 01-06-2012, 08:26 PM   #2 (permalink)
TN USER
razr988's Avatar
View razr988's Photo Gallery
Mines a 93 V6 also.
I don't know if its the same problem but recently at random times. I warm up the car and do errands as usual. Then out of nowhere I accelerate and feels like im forcing it and once I go to that certain high RPM its normal. Then I slow down and the car feels like its dying. Then I get home and turn off the car. It doesn't turn on. .. Im guessing in my case its the battery. Because then i jump-start the car and turns on. The battery isn't that old though but it isnt the first time that battery has given me problems.
or it can be the same case as yours.
-est.1991-
-93 camry V6 SE
-http://www.cardomain.com/ride/3864106/1993-toyota-camry-se-sedan-4d
razr988 is offline   Reply With Quote
Old 01-06-2012, 08:41 PM   #3 (permalink)
I just replaced the battery, also the cv shafts are brand new also. I'm thinking about pulling the coolant temp sensor to see of it is that.
I am just sick and pretty tired at the moment, thanks for reply though
Old 01-06-2012, 09:46 PM   #4 (permalink)
View 1996camry's Photo Gallery
I don't think fuel pump is your problem...
have a question.... you said your car can't start went hot
can you crank and start up when cold?
1996camry is offline   Reply With Quote
Old 01-07-2012, 01:06 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
check that (bold) first.
another possible option is a micro-thin/hairline crack in the distributor coil (it shows symptoms pretty much only when hot).
Any ideas guys?
Old 01-07-2012, 06:24 AM   #6 (permalink)
Yeah it does start up while cold, lately, since yesterday i havent started it, i will start it today and see where is stands.
Fenixus Yeah I have done a mild research and that is what some people alwways say..
by next question is where is the Coolant Temp Sensor on a V6, I was unsure because Ive heard it was in the radiator or near the valve covers...
do you all know?
Old 01-07-2012, 07:23 AM   #7 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Crank as in weak starter, or turns fine but just doesn't fire?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-07-2012, 07:28 AM   #8 (permalink)
the starter is fine, it starts up but when hot, it shuts off after two seconds
Old 01-07-2012, 07:32 AM   #9 (permalink)
But it runs fine when hot, just doesn't hot start? How long does it have to sit and cool before it will start?
Old 01-07-2012, 08:05 AM   #10 (permalink)
The more i drive it, the worst it drives, ya it doesn't start after i've been driving for awhile, umm it depends... maybe 3-4 hours, but its kind of cool outside. so ya
Old 01-07-2012, 08:27 AM   #11 (permalink)
... maybe 3-4 hours
Have you checked for spark when no start?
Old 01-07-2012, 08:55 AM   #12 (permalink)
the plugs, wires and distributor is good, all are relatively new
Old 01-07-2012, 09:10 AM   #13 (permalink)
ok now the it being cold, it doesn't stay on, starts but shuts off
Old 01-07-2012, 09:24 AM   #14 (permalink)
I didn't ask that. I asked if you had TESTED for spark when the car does not start? Slapping on parts without testing is not diagnosis.
Old 01-07-2012, 09:47 AM   #15 (permalink)
oh ok, no i didnt test for spark, however it does start, but then it shuts off... how do i test for spark?
