how often you replace struts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2012, 10:06 PM   #1 (permalink)
View 5thgencamryJ's Photo Gallery
I have to replace every 60000 miles I think. Is this normal for this generation?
I drive many bumpy roads (city). Not smooth freeways.
5thgencamryJ is offline   Reply With Quote
Old 01-07-2012, 12:08 AM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Mine were done around 120k, and my dad had my car before and he drove M-F on one of the worst roads in Dallas. What surprised me is my cousin's 06 CTS with 140k miles still has original suspension in Houston(absolutely terrible roads) and it rides like new, saw with my other cousins 04 Accord, same mileage, original suspension, same city. I wonder if the struts learn to tolerate the bad roads.
pmesfun is offline   Reply With Quote
Old 01-07-2012, 01:02 AM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
all depends on area you are driving. I just posted it in other thread, will just copy and paste here
in my area (NJ, not far from Lincoln Tunnel to NYC) struts do not last long. I replaced OEM struts on wife's car at merely 35k-40k miles or so? all miles were driven mostly in NJ and also on some interstate highways down to North Carolina (prev owner was traveling there a few times a year as he said).
on the other hand I have another Toyota from Florida which still had original front struts at 122k miles when I bought it over there ... had to replace them soon after coming to NJ though , they got bouncy (were all fine back in FL yet) to the point I was almost having sort of sea/road sickness when going at speed limits on bumpy highways around my town
Old 01-07-2012, 01:44 AM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
For front MacPherson designs maybe 50K miles the manufacturers suggest is about right. For shocks (like on Honda SLA systems) they seem to last over 100K without problems.
Old 01-07-2012, 04:59 AM   #5 (permalink)
View Doug S's Photo Gallery
I live in NJ and have 170K on the fronts and 60K on the rears, if they are not leaking then ussually they are OK. The rubber is going on the rear ones but my ride is not affected, tire wear is normal and handling is fine-for a family sedan type of car.
60K sounds excessive to me but it's your ride and wallet. What Kind are you installing?
D
Doug S is offline   Reply With Quote
Old 01-07-2012, 01:06 PM   #6 (permalink)
Gameroom cash: $872000
View zb420's Photo Gallery
This might be a good thread for this question.
Not sure if my struts have been changed or not...I tend to think they have being that I had to replace a rear axle because I was living at one time deep in a canyon, with 20 miles up and down to get to civilization. That was in about '02.
This is not a new issue but I'll ask it here. When I go over city made humps and bump I take them slow. I still hear a little squeaking coming from the rear, I think from one side.
My first thought is that is is a strut?
...am I correct?
p.s. thanks to whomever has been putting a little money in my gambling account... I had another bad run...
1993 Camry LE 2.2l
Original owner
112k mi.
zb420 is offline   Reply With Quote
Old 01-07-2012, 01:36 PM   #7 (permalink)
Avy
probably sway bar bushings.
The Following User Says Thank You to pmesfun For This Useful Post:
zb420 (01-08-2012)
Old 01-07-2012, 02:05 PM   #8 (permalink)
we talking big bucks here?
1993 Camry LE 2.2l
Original owner
112k mi.
Old 01-07-2012, 02:23 PM   #9 (permalink)
Avy
Yeah about 20 bucks.
Old 01-07-2012, 05:40 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
or around $15 if you buy Duralast bushings from Autozone or Moog bushings from Advance Auto online (with P20 code for 20% off). to replace you raise the whole axle off ground, remove wheels and unbolt 2 14mm bolts holding bracket on each side (do them one side at a time),swap the rubber bushing (super easy) and then bolt back on 14ft-lbs and done
other possibility is the exhaust or muffler hanger is rubbing metal to metal, I had such noise coming from V6 car in rear (passenger side) while sway bushings were making a squeak coming kinda from middle rear or something...
The Following User Says Thank You to fenixus For This Useful Post:
zb420 (01-08-2012)
Old 01-07-2012, 08:25 PM   #11 (permalink)
Avy
Bolt size is 12MM IIRC.
Old 01-07-2012, 08:31 PM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah, probably it is. I can't remember well.
Old 01-08-2012, 12:03 PM   #13 (permalink)
Problem is guys is that I am not as mechanically inclined as you all. I wish I was but I'z ain't... so I have my mechanic do it... sounds like it will take him less than an hour if that's it?
1993 Camry LE 2.2l
Original owner
112k mi.
Old 01-08-2012, 12:17 PM   #14 (permalink)
Gameroom cash: $153405
View redgtxdi's Photo Gallery
I'm really tired of this apple ios5 safari crash thing.......so before it crashes again.....
Try getting under there yourself and spraying tho bushings with some silicone spray before dropping off with your mechanic. Might work. Since I've found silicone spray, I've silenced almost everything except the dog!
1998 Camry 2.2L auto. 195,000 "mostly" trouble-free miles. She needs a little work but still purrs.
1995 Geo Prizm 1.6L. 165,000 "mostly" trouble-free miles. (need to sell soon)
2011 Venza 2.7L. 5,000 miles wondering if there ever was an NVH crew assigned to Venza
redgtxdi is offline   Reply With Quote
The Following User Says Thank You to redgtxdi For This Useful Post:
zb420 (01-08-2012)
Old 01-08-2012, 12:26 PM   #15 (permalink)
lol, ah, OK.... a bushing you say... I'll have to use ''the Google" as Duba used to say. Say hi to you dog for me....
just occurred to me that silicone might be better than W-D40 for squeaky doors?
EDIT: actually my mechanic does the work where I live... and he's real good. He probably would come over and check it out.
I've dealt with him now a bunch of times and I'm beginning to like him more and more...
*My last mechanic before he left to go home to Thailand I had for about 17 yrs. Before he left he told me my alternator was going out and had me listen to the screwdriver. All I heard was a part working, a year later it's still working just fine... BASTARDO!
1993 Camry LE 2.2l
Original owner
112k mi.
