Possible solution found for vibrations at idle? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2012, 04:31 PM   #1 (permalink)
View nathanours's Photo Gallery
3rd Generation Possible solution found for vibrations at idle?
Hey all, I've got a 96 Camry LE with the 5SFE engine, and I always have had annoying vibrations while in drive but stopped, like when waiting for a light.
I had a weird shifting feeling I could feel through the gas pedal when I'd accelerate from a stop, and realized my lower front engine mount was shot, and the engine was torquing back. I replaced it, and my idle vibrations actually got worse, but the shifting feeling was fixed. It was almost as if the engine was now hooked to the car better and transferred more of the vibrations to the steering wheel and frame.
I then replaced the top dogbone engine mount because it was deteriorating, and this helped a little but not much. The main thing annoying me was how the vibrations would cause squeaks and rattling I could hear that drove me crazy.
A couple days ago I wanted to clean out my fuel system and had heard good things about this stuff called BG44K. The only place around here that carries it is NAPA. You have to ask for it as they keep it behind the counter, and it cost almost $25. It comes in a can and I added it to my gas tank with a funnel.
After a couple days of driving probably 95% of the vibrations are gone! My engine didn't feel like it was running roughly at all before, but now it is so much smoother. I can feel almost no vibrations through the steering wheel anymore.
Just wanted to let you guys know in case any of you may be having the same problem. I didn't expect it to have such a good effect on reducing the vibrations at all. Hope this helps some of you out, the $25 is well worth it!
nathanours is offline   Reply With Quote
The Following User Says Thank You to nathanours For This Useful Post:
fenixus (01-07-2012)
Old 01-07-2012, 07:40 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
may give it a shot on both toyotas. have never tried BG44K and so far read only good opinions about it
thanks for a review.
My wife's 4 cyl '00 has still some very slight idle vibrations in driving gears at full stop despite the fact that it now has a new IAC valve and all engine mounts replaced.
before I start tearing apart the cylinder head on this car I will surely try BG44K.
here is some review link from BITOG:
http://www.bobistheoilguy.com/forums...Number=1355086
Old 01-07-2012, 08:33 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
one important thing though. after you ran the full tank of gas with BG44K in it, refill fresh fuel AND change the oil!
someone did a UOA on oil after running a gas tank with BG44K and it seemed it depleted the TBN of his oil, UOA showed zero TBN (very bad).
http://www.bobistheoilguy.com/forums...&Number=268101
other opinions on BG44K I find, pretty impressive. seems that BG44k is like 3x more concentrated dose of Techron and much better than sea foam (in gas tank that is), interesting.
http://www.bobistheoilguy.com/forums...&Number=266622
http://www.wrxtuners.com/forums/f52/bg-44k-whoa-22270/
Old 01-07-2012, 09:32 PM   #4 (permalink)
other opinions on BG44K I find, pretty impressive. seems that BG44k is like 3x more concentrated does of Techron and much better than sea foam (in gas tank that is), interesting.
Thanks for the advice, I was planning on changing the oil in about 500 miles, but I'll move it up to when I finish this gas tank.
Old 01-08-2012, 10:21 AM   #5 (permalink)
View kent55's Photo Gallery
Nice review...my Camry shakes so bad in D at stops, I shift to N almost every time...
I want to try this stuff but I just changed my oil 5 days ago....I may wait a bit.
1994 Toyota Camry (3rd owner)
2005 Scion tC (1st owner)
kent55 is offline   Reply With Quote
Old 01-09-2012, 01:29 AM   #6 (permalink)
Ya, it was weird because I wasn't really expecting it to fix the vibrations. I've read on here many times that people have this issue though so maybe it will work for some of you.
I drove all day today on it and noticed a gain in power as well. Kind of interesting. I'm only through about a third of the treated tank, so it'll be interesting to see what happens.
My brand new Michelin Primacys are doing awesome as well. So much quieter than the Bridgestones before them. Definitely improved handling quite a bit as well.
Old 01-09-2012, 01:58 AM   #7 (permalink)
Gameroom cash: $122650
View 93cr250's Photo Gallery
if anyone else trys this with good results report back here, my dads camry shakes BAD at idle in d and mine is starting to shake
1995 Camry LE sedan 4cyl auto, tan 165,000 miles- mine
1996 Camry LE sedan 4cyl auto, white 206,000 miles- dads
93cr250 is offline   Reply With Quote
Old 01-09-2012, 04:17 AM   #8 (permalink)
View hodgoes2001's Photo Gallery
My camry hates normal 91 Octane fuel with a passion..
it runs rough and looses 30hp compared to 95 Octane Fuel..
just what i found...
hodgoes2001 is offline   Reply With Quote
Old 01-09-2012, 12:55 PM   #9 (permalink)
Isn't the normal for premium 91? Where do you buy 95?
Old 01-09-2012, 01:19 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
Australia uses different octane calculation over there than we do in USA.
in US we use AKI octanes, while for instance in Europe and Australia they use RON octanes.
we have fuel grades (AKI octanes):
regular 87, plus 89, premium 91 (or 93 in some areas like here)
they have corresponding fuel grades (RON octanes):
regular 91, plus 95, premium 98
http://en.wikipedia.org/wiki/Octane_rating
The Following User Says Thank You to fenixus For This Useful Post:
nathanours (01-09-2012)
Old 01-09-2012, 01:26 PM   #11 (permalink)
Very interesting, thank you. So for me to use the equivalent to what he is using, I should put in 89?
Old 01-09-2012, 01:32 PM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
according to the chart on wikipedia site, the Euro95 (95 RON octane) is closest to our American premium 91 (AKI) octane. so unless your local station's premium is 93, go with premium 91 to see similar difference.
premium 93 (AKI) would correspond closely to Euro98 (98 RON octane) fuels.
Old 01-09-2012, 03:04 PM   #13 (permalink)
I've tried running 84 and 91, and they both feel the same and get the same gas mileage for me. Interesting he would have such different results in a similar car.
Old 01-09-2012, 03:45 PM   #14 (permalink)
抵抗は無駄です
fenixus's Avatar
well, first of all a properly maintained 5s-fe engine which is "in tune", is optimized to run best with regular 87 (AKI) octane featuring 9.5:1 compression ratio.
generally, this engine should run same good on 87 or 91 fuel. if it runs significantly better on premium fuel, this could be an indication of engine being out of tune (calling for higher octane rating trying to compensate).
I wouldn't worry about it much.
