How do i remove the AC Compressor, or just the clutch!? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2012, 09:26 PM   #1 (permalink)
Haters Gon Hate ;]
gr91's Avatar
Gameroom cash: $130750
View gr91's Photo Gallery
My 92 5sfe ac compressor clutch is done, i want to remove it.
how do i remove the compressor, or how do i remove the clutch. obviously if i can remove the clutch with the compressor on the car still then cool beans if not, i will just have no compressor. so how do i do it. i bought a chilton manual. for the camry. no help there, and the info on TN is not what im looking for. i need some directions, and pictures would be great!
-1991 Corolla Dx - gone :/
-1992 Toyota Camry LE- Restoration Project-FAILED!
-2008 Honda Civic ex Coupe!
gr91 is offline   Reply With Quote
Old 01-08-2012, 09:41 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Did you find this thread? I doubt it can be done with the compressor on the car.
BMR is offline   Reply With Quote
Old 01-08-2012, 09:44 PM   #3 (permalink)
Haters Gon Hate ;]
gr91's Avatar
yeah i looked at it, but if i cant do it on the car then i guess i need to remove the compressor, so that thread didnt really help because it didnt tell me how to remove the compressor !
Old 01-09-2012, 12:04 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
i havent removed a compressor from a camry, but on other vehicles there arent too many bolts holding it in place (minus the coolent lines). if you can leave the lines attached and just have the compressor loose, you *should* be able to use a gear puller and pull of the clutch assembly. sorry if this doesnt help.
Old 01-09-2012, 12:48 PM   #5 (permalink)
View bolink654's Photo Gallery
Yeah, just remove the belt and the 4 bolts (maybe it was only 3?) holding it to the engine, then you can work on the clutch.
Hopefully you have better luck than I did.
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
bolink654 is offline   Reply With Quote
Old 01-09-2012, 01:22 PM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
As in putting it on a bench? R12 or R134a? You'll need to have the system evacuated then remove the refrigerant lines and the four bolts that hold it to the mounting bracket and engine. After it's off you'll need a tool to hold the pressure plate then another bolt tool (SST) to separate the pressure plate from the shaft. Never done this one so others might give you an alternate tool method that won't damage anything. If you have access then keeping it on the car is a lot less labor and you won't have to have the system vacuumed and re-charged.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-09-2012, 04:34 PM   #7 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
I'm not sure if any of this will apply to your setup. Mine's a 2000 1MZ, but some of the stuff will be the same.
A/C compressor/clutch vibrates at idle.
It turned out my compressor was shot and I replaced the compressor as well as the clutch. I was going to do complete DIY on the whole procedure but I never got around to it.
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is online now   Reply With Quote
Old 01-09-2012, 10:04 PM   #8 (permalink)
Haters Gon Hate ;]
gr91's Avatar
thanks guys, im thinking of just saying F*** the compressor and clutch, grabbing a thor hammer and just knocking the shit our of it!
In anycase the 2 washer on the bolt thing, was helpful! Anywya, got a new problem, It flooded crazy today, went through that shit, got to work safely but my alternator light came on, shit. thought i f***ed it up! turns out, im good! BUT the belt was super loose! i looked down and it seems as though the harmonic balancer big pulley is GONE! mustve fell in one of the puddles. anyway, i have a f***ed up harmonic balancer, and a loose belt, :[ im f***ed! i dont feel like trying anymore... i really dont! i can get the parts at a big discount since i work for oreilley auto parts, but now i have to find a thread for the HB! f***.. oh well, thanks guys,
i'll look to see about the damn Clutch, im thinking of just getting a huge breaker bar, turning on the car with no belt on it, engaging the Magnetic part and trying to do it like that! How well do you guys think that will go?
Last edited by TrailDust; 01-16-2012 at 11:31 AM. Reason: Foul language edited. Please, use the appropriate language, thanks!
Old 01-10-2012, 01:20 AM   #9 (permalink)
Wont work. In that thread, I was trying to replace the clutch. As such, I wasn't worried about damaging it. I pryed with all sorts of various tools, and made my own SST. None of which worked. Ended up drilling holes in it and fashioning up a puller of sorts.
Old 01-10-2012, 01:41 AM   #10 (permalink)
Haters Gon Hate ;]
gr91's Avatar
So f*** it. I guess I'm going to remove the whole thing. Ill takeit to a shop to flush the system ten pull that muther f***er out....
I guess ill have to rent the harmonic balancer pulley puller from work. Remove it then replace it.
While I'm at it. I'm going to explore removing my cruise control system since its just space and doesn't work! ahh too much shit to do not enough time!
Old 01-14-2012, 09:41 AM   #11 (permalink)
Haters Gon Hate ;]
gr91's Avatar
So yesterday I replaced my harmonic balancer. Did the start bump method. I don't think I tightened up right though. Will check at some point. While I was there, removed the a/c compressor, I had no freon whatsoever. None -_- anyway came off pretty easily I guess. Took off the lower radiator hose, droppd fluid. then got a 3inch extension with a 12mm socket to removethe top, used a pipe since it was a little hard. Then there are 2 in sight lower, took the left one off easily. The right one you have to remove the 2 lines connecting to the compressor. Then off with the right bolt, took it off and slipped on the non a/c belt! It Idles soooo much better! Before it would misfire, and now its steady rpms. I remembered looking at the belt one day and seeing it move at normal speed but every once in a while it would slow down then go back to normal speed! That was definitely the a/c compressor! Well , now the vehicle is good, but I have to make sure the harmonic balancer is torqued to spec. I didn't even torque it correctly! :s
Sent from my SGH-T839 using AutoGuide.Com Free
