Air fuel ratio help? (regarding air intake) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2012, 01:02 PM   #1 (permalink)
View nathanours's Photo Gallery
3rd Generation Air fuel ratio help? (regarding air intake)
Hey everyone, hope you are all doing well.
So, I put in a new air intake in my 96 5S-FE camry because the old piping was cracked and falling apart. I just kind of built my own using different pieces of piping.
I routed it to where the new conical filter is behind the battery and used the old air filter box to create a heat shield from the rest of the engine with a skill saw and a lot of fitting and cutting. I then wrapped the whole thing in heat resistant tape (not sure if this helps, but it was worth a try).
I drilled holes in the new intake in roughly the same places that they were in the old one to put in the vacuum hose (I think ?) and the O2 sensor.
My friend said that now that the airflow is less restrictive, I need to enrich the engine to compensate for greater air flow. How do I do this? I have adjusted it to maintain a smooth idle on my brothers 4-runner and know it adjusts in clicks. Do I even need to do anything since my idle is fine? Will giving it more gas give me more power?
Thanks,
Nathan
nathanours is offline   Reply With Quote
Old 01-09-2012, 03:59 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
How does he know that?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-10-2012, 06:48 AM   #3 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
You don't need to do anything to enrich it, your friend is mistaken. You will not get that much more flow.
Pvt-Public is offline   Reply With Quote
The Following User Says Thank You to Pvt-Public For This Useful Post:
nathanours (01-11-2012)
Old 01-10-2012, 09:25 AM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
the ECU will enrich the fuel in mixture accordingly to maintain the best optimal air/fuel ratio for more incoming air.
the difference is like 5% max, leave it to the ECU and enjoy
The Following User Says Thank You to fenixus For This Useful Post:
Old 01-11-2012, 07:15 PM   #5 (permalink)
Thanks guys, this answered my question.
