Here I go Again Need Help Rear Motor Mount - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2012, 04:30 PM   #1 (permalink)
View skilew's Photo Gallery
Ok, here I go again on trying to remove the rear motor mount on my 1994 Camry (4 cylinder). I have removed the 3 bottom bolts and even removed the top 14MM nut, but how do I remove the motor mount after that?
I tried lifting the engine with a jack & block of wood supported under the oil pan but I never could get the motor mount to clear. I was afraid to jack up too much on the engine.
Is this the right process or am I missing something?
Any suggestions will be greatly appreciated.
skilew is offline   Reply With Quote
Old 03-15-2012, 06:29 PM   #2 (permalink)
View CAMRYGASS's Photo Gallery
i was actually interested in doing this to my camry.... is it a difficult project for one person? Did you finish it? and if so... tips?
CAMRYGASS is offline   Reply With Quote
Old 03-15-2012, 06:51 PM   #3 (permalink)
cmryhldr's Avatar
View cmryhldr's Photo Gallery
rear motor mount
See if this DIY helps.
5SFE Motor Mount How-to
Lots of good stuff in the DIY section.
01Camry 4 cyl
04 Highlander V6
cmryhldr is offline   Reply With Quote
The Following User Says Thank You to cmryhldr For This Useful Post:
CAMRYGASS (03-15-2012)
Old 03-16-2012, 03:18 PM   #4 (permalink)
View Judge2's Photo Gallery
I know that the dogbone motor mount must be disconnected. ....
Judge2 is offline   Reply With Quote
