Originally Posted by Pvt-Public
Not really a fair comparison. 9 years newer, completely different engine than a 2.2 with unknown thousands of miles on it. And at best what would you get a 5% power increase (probably less) you wouldn't even notice that 6 extra HP on a 3000 lb car.
Not true again. The engine in question was also a 5SFE (maybe it was 2001) with the only difference being the ignition setup and balance shafts.
Also the power increase isn't the only reason you upgrade the exhaust. Looks are a major reason. Plus his exhaust is rusted off. He has to do something with it anyway. Why not do something worth it. Also a 5% increase probably would be felt especially when trying to keep up with faster and faster cars at the lights. 132HP is always better than 130HP no matter how you spin it.
I am not saying he should go ahead and put high compression pistons, a full length cold air intake, cams, a megasquirt ECU, and a full exhaust system. I am saying that if your exhaust rusted off there is no reason to not upgrade the exhaust while you are repairing it already. You generalized that all mufflers are loud. That is most certainly not true. Even a new 2GRFE with mufflers deleted is still manageable in its sound.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post
