01 camry-no signal to fuel pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2012, 01:00 AM   #1 (permalink)
View ricecloud's Photo Gallery
Request help from the nation w/ no power to fuel pump, checked relays as per repair manual info for EFI main relay & circuit opening relay as tested by continuity check & battery powered applied & continuity checked on relay used on vehicle. The battery powered check test good as per manual on both relays, the continuity only checks do not test ok as per manual as neither did 2 other new relays @ 2 different stores. The relay sockets power up with ignition turned on/ existing relays power up horn if interchanged. If relays power other items, are they good as described or is the info contained in manual not correct. The relay box contains other relays with same pin configurations & numbers ex. fan 2, fan 3, mg clt, horn. The ground @ harness at pump checked good w/continuity test to body. The fuses view ok. Any help would B great, thanks Craig
ricecloud is offline   Reply With Quote
Old 01-10-2012, 05:39 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Does the 01 have an inertia switch?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
The Following User Says Thank You to Stillrunning For This Useful Post:
ricecloud (01-11-2012)
Old 01-10-2012, 01:51 PM   #3 (permalink)
stillrunning----i am @ the mercy of information provided by Hay / Chilt repair manuals & have not seen anything listed for ineritia switch. S Run, i thank u 4 your response
Old 01-10-2012, 05:25 PM   #4 (permalink)
Owners manual?
Old 01-10-2012, 08:23 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
have you checked if you are getting 12V at the fuel pump directly? or that's the whole problem, because this power doesn't even show up at relay sockets?
is the 15A blue EFI fuse OK?
The Following User Says Thank You to fenixus For This Useful Post:
Old 01-11-2012, 01:35 AM   #6 (permalink)
Dave's
Gameroom cash: $121550
View Dave's's Photo Gallery
I'd check all your fuses first but also look for a red-capped device. Seems they sell an aftermarket fuel cutoff switch which may be under the hood or behind the left kick panel. The one's I saw had a squarish red plastic cap on them. I doubt that's your problem but you never know.
Dave's is offline   Reply With Quote
The Following User Says Thank You to Dave's For This Useful Post:
Old 01-11-2012, 01:33 PM   #7 (permalink)
View oldfirebird's Photo Gallery
Getting 12 volts is one thing, getting enough current is another. Long story short I had a corroded fuse socket in my camper. It passed enough to move the meter but not light off a dozen bulbs. Check your wiring diagram. If the fuel pump relay wires straight to the pump, jumper the wire in the fuse box directly to the battery. Just add a ten or twenty amp fuse in your jumper wire to prevent fires.
If that works, go from the relay power supply wire to the fuel pump wire effectively eliminating the relay all together
oldfirebird is offline   Reply With Quote
The Following User Says Thank You to oldfirebird For This Useful Post:
Old 01-11-2012, 02:24 PM   #8 (permalink)
S run-- it would B the repair manual
Old 01-11-2012, 02:29 PM   #9 (permalink)
Feinixus--efi fuse good, sockets power up, no power @pump Thanx 4 your input
Old 01-11-2012, 02:34 PM   #10 (permalink)
Dave-- i will take a look, thank youuuuu
Old 01-11-2012, 02:41 PM   #11 (permalink)
No, no, I meant the info may be in the owners manual as is in my Ford's owners manual about the location of the inertia switch.
Old 01-11-2012, 02:48 PM   #12 (permalink)
OF Bird--thank u 4 the response
Old 01-11-2012, 02:52 PM   #13 (permalink)
抵抗は無駄です
fenixus's Avatar
if all fuses are good and + power is present at relays and relays themselves are good, then it must be the positive side of wiring going to pump.
as mentioned try running a jumper wire to bypass the car wiring between relay and pump, make sure there is no other electrical stuff in between.
Old 01-11-2012, 02:52 PM   #14 (permalink)
S run--- Bingo, soooook ,Thanks again
