need help with no start please!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2012, 06:07 PM   #1 (permalink)
View cjp828's Photo Gallery
I am working on a 2001 camry with a 2.2 the car started shaking and loosing power and then died and i can not get it started. I have codes p0300, p0301, p0302, p0304, p0401, p0402 and p0115. I have replaced the egr valve and cleaned egr pipe, replaced both ignition coils, and replaced fuel pump. I also replaced spark plugs and wires about 2 months ago. I have been trying to get the car started and have failed so far can anyone please help?????
cjp828 is offline   Reply With Quote
Old 01-11-2012, 06:10 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
First thing I'd check is if the timing belt broke. Remove the cover and take a peek while cranking the engine. Sometimes a few teeth shear off and it looks intact but it's not.
BMR is offline   Reply With Quote
Old 01-11-2012, 06:19 PM   #3 (permalink)
Thank you for the advice I did remove the top 2 screws on the cover just to take a peak and the belt dose not appear to be snapped but it did look wore out so I will have to fully remove the cover and inspect the belt first thing in the morning.
Old 01-11-2012, 09:16 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Also do an ohmmeter test on the engine coolant temperature sensor. It may be going bad. At operating temp it should be about 200 ohms IIRC, but you can google up a chart.
