ok sorry.. stock internal wastegate... so i havent even seen past 3 psi before the ecm cut the fuel. 89420-17030 93 mr2 turbo map sensor i bought off ebay.. whats happening is the second the ecm see's the signal from the map sensor when it starts to boost it cuts the fuel.. and sets check engine for P0105 for MAP sensor circuit range... what settings do I have wrong.. AFC settings said stock 5sfe is a
PR-3 and the 3sgte is a
PR-2 sensor.. so I set it for
PR-2 in and
PR-3 out... The second it sees any boost it completly cuts out.. I figured that was the whole point of the turbo map sensor.. so the stock computer wouldnt bug out. I really need to get this
