1995 Camry timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2012, 11:12 PM   #1 (permalink)
1995 Camry LE
View mewong's Photo Gallery
3rd Generation 1995 Camry timing belt
My car has 53,613 miles on it. 2.2 liter 4 cyl. Do I need to change the timing belt? I've seen some threads on here where they say 60,000 miles is when it's suggested to change, but others seem to go 100K without any problems. Do I need to worry because it's 17 years old? It's a 2nd car and is driven less than 5000 miles per year. I'm in Los Angeles, CA.
Thank in advance.
mewong is offline   Reply With Quote
Old 01-12-2012, 11:25 PM   #2 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
Was it stored outside or in a garage? I would cause ozone in the air (heavy in Los Angeles) degrades rubber over time through oxidation.
Just my 2cents.
95 Camry LE I4 195k
bdy0003 is offline   Reply With Quote
Old 01-12-2012, 11:30 PM   #3 (permalink)
1995 Camry LE
The car was in Oregon until 2007. Has been in Los Angeles since then and kept in a garage.
Old 01-12-2012, 11:38 PM   #4 (permalink)
Chemist at Chevron
Its really up to you. Since its a non-interference engine, if it breaks, you just put in a new one along with other parts you should change. That being said, you don't want it to conk out on you when on the freeway adding to the congestion.
I would replace it since its old. Since it has low mileage, you know you or someone will hopefully drive this thing for awhile longer.
95 Camry LE I4 195k
Old 01-12-2012, 11:59 PM   #5 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
As bdy0003 posted, having 16 years on the T-belt is questionable. Toyota recommend 60K on the Gen 3 (or 6-7years on some books, which ever come first) Rubber will dry and any small cracks required replacement.
If you plan to keep the car. Do the replacement right the first time. I would replace the water pump, idler pulley, tensioner, and seals if they are leaking. (I have to do my timing belt job twice because I keep old parts on)
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 01-13-2012, 09:48 AM   #6 (permalink)
Gameroom cash: $872000
View zb420's Photo Gallery
I didn't change my belt on my '93 until over 100K mi... only because it slipped my mind.
I am not suggesting that at all... upon inspection, the belt was separating at one of the teeth.
I'd just get it done and take it off your mind.
Personally knowing this was just done gives me a bit more peace of mind, it will you too.
p.s. broke as a joke again, if you have some extra $$$ you can give me for my game-room that would be great.
1993 Camry LE 2.2l
Original owner
112k mi.
zb420 is offline   Reply With Quote
Old 01-13-2012, 04:23 PM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
After so many years I'd change it. In fact if you can do your own work, I'd change out:
GATES K030295 Micro-V AT Power Steering Belt $5.14
GATES K050435 Micro-V AT Alt/AC Belt $14.10
FEL-PRO TCS45920 Crankshaft Front Seal Set $5.10 (includes pump o-ring)
FEL-PRO TCS45641 Camshaft Front Seal $3.66
NATIONAL 221820 Polyacrylate Oil Pump Shaft Seal $2.86
GATES TCK199 (1 Belt, 1 Tensioner, 1 Idler) Timing Belt Component Kit
$52.89
STANT 48278 180° w/Jiggle Pin OE Type Thermostat $10.94
AISIN WPT010A Water pump w/o housing $30.79
FEL-PRO VS50304R1 Valve Cover Gasket Set w/Spark plug tube seals
$18.26
Subtotal $143.74
Shipping about $20
You can also use OEM equivalent parts from eBay's Aircabinman or buy "Toyota" branded parts from TN sponsors like ToyotaPartsMan.
Old 01-13-2012, 06:42 PM   #8 (permalink)
Gameroom cash: $814501
View zythr's Photo Gallery
Just my 2cents.
Isn't that what the timing belt cover is supposed to protect against?
zythr is offline   Reply With Quote
Old 01-13-2012, 07:04 PM   #9 (permalink)
Chemist at Chevron
Timing belt cover is not air tight and does not protect against heat, so not at all.
95 Camry LE I4 195k
