No check engine light is on, I assume? I'm thinking the ECT sensor. It's on the driver's side of the engine, sticking up vertically out of an aluminum pipe attached to the engine block. It's got a green 2-wire connector on it. Try checking its resistance with the engine cold and hot. Should be about 4k ohms cold, 400 ohms warm.
FWIW, I've done this adjustment on mine, and never had problems like yours is having. I went as high as ~6 clicks lean. It seemed to be losing power, so backed down to 3 or 4 clicks. So I don't think the AFM adjustment is the culprit.
OH, and welcome to TN!
