Transmission Fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2012, 10:37 AM   #1 (permalink)
o048.
shyshadow48's Avatar
View shyshadow48's Photo Gallery
3rd Generation Transmission Fluid?
Hey guys,
I have a 96 toyota camry, automatic, V6.
I have a questions about the transmission fluid:
1. Where is the dipstick located if there is one?
2.where do I put the fluid to?
The only thing I see is the oil dipstick, power steering,break fuild,coolant,and oil compartments,
But NO transmission fluid anything?
If someone can provide me with some answers. I will appreciate it A LOT.
shyshadow48 is offline   Reply With Quote
Old 01-13-2012, 10:39 AM   #2 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
The location is documented in the owner's manual, available online at the manufacturer's web site if you don't have the paper copy.
TedL is offline   Reply With Quote
Old 01-13-2012, 01:04 PM   #3 (permalink)
View CarryMeBF's Photo Gallery
Originally Posted by shyshadow48 View Post
Hey guys,
Isn't it just right of the Engine Oil Fill Cap? Sticking up with a brownish orange dipstick looking thing... Circled in pic below. That is where you check and fill.
2001 Toyota Camry LE V6 with 156k miles
2007 Toyota Sienna LE with 89k miles
CarryMeBF is offline   Reply With Quote
Old 01-13-2012, 01:42 PM   #4 (permalink)
o048.
@CarryMeBF : thanks for the picture. I just noticed it when I went to check the engine. But where does the transmission fluid go in?
I know the motor oil goes where it says motor oil. & power steering where it is indicated.
But what about the transmission oil? Where does it go?
All I know is where the dipstick is ^__^ .
Old 01-13-2012, 01:45 PM   #5 (permalink)
You fill your transmission where the transmission dipstick is, you'll have to use a funnel.
The Following User Says Thank You to CarryMeBF For This Useful Post:
shyshadow48 (01-13-2012)
Old 01-13-2012, 01:48 PM   #6 (permalink)
o048.
Thank you very much
Old 01-13-2012, 03:56 PM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Yeah, use a funnel like one from the following $0.99 set:
http://www.harborfreight.com/4-piece...l-set-744.html
But before you add anything make sure to check the ATF level first. Add no more than 8 oz at a time if needed.
Has the fluid ever been changed or the pan serviced in all these years? You can search the DIY section and find articles on these topics. But before you add any ATF, make sure you properly check the level first on a few different occasions. Here is an example of ATF service (V6 similar to this I4 DIY):
DIY: 5S-FE Transmission Fluid & Strainer Replacement Procedure
Basically with the engine running at operating temperature - about 5-10 miles of local driving should do. On level ground with the parking brake set and gear selector run through all gears, stopping a few seconds in each and return to Park. The level should be between the HOT marks.
The transmission uses Dexron III type fluids. Including Walmart SuperTech ATF, SuperTech Mercon-V, Castrol Import multi-vehicle ATF, or Mobil-1 ATF. Always check the label, it should say suitable for Dexron III type. Do not use ones only for Toyota T-IV or WS.
And if you decide to do a drain/refill, measure what you drain out first and add that amount back in after making sure the ATF level is between the HOT marks. It's easiest this way, and just double check the ATF later as stated above afterwards.
The Following User Says Thank You to JohnGD For This Useful Post:
Old 01-13-2012, 04:52 PM   #8 (permalink)
o048.
Thanks that's helpful information. I think my brother flushed it around 6 months ago. I totally forgot about it until
Now since I'm getting ready to do all the basics again. I didn't know about the dextron III. I'm sure toyotas fluid has it. Thank you.
Old 01-13-2012, 06:59 PM   #9 (permalink)
If it was done 6 months ago then just check the level and condition should be sufficient. The ATF should be pink/red and not brown/black and should smell closer to the new fluid than a burned oil.
It's fine if you decide to get the GM Dexron III from your local dealer, but you can get them cheaper just about everywhere else unless the dealer gives you a discount.
Did your brother drain the differential too?
Old 01-20-2012, 09:20 PM   #10 (permalink)
o048.
Hmm I doubt he changed the differential. I guess ill simply do the flush and change the oil. Just to be sure.
Old 01-21-2012, 02:06 AM   #11 (permalink)
Walmart's SuperTech Mercon-V (all new formulations are suitable for Dexron III type applications) or Mobil-1 are nicer in the differential and PS steering system.
Old 01-28-2012, 12:01 PM   #12 (permalink)
View HawkeyeKid18's Photo Gallery
I have a question about the ATF. I bought my 99 Camry about a year ago from the dealership with 88,900. I got my oil changed today at Jiffy Lube and they mentioned that the ATF looked dark and they can do the exchange for $75.
I looked at my vehicle history and the last time transmission service was done was in 2/2007 at 86,400 with synthetic fluid at the dealership. Now I'm at 100,500 miles.
Now the confusion is should I just do the drain/refill or the full exchange? I read around a few forums that a full exchange might be a shock to the system if it hasn't been replaced in awhile.
Thanks!
1999 Toyota Camry LE, 2.2L I4 DOHC 16V FI Engine
Alpine CDA-105 HU
HawkeyeKid18 is offline   Reply With Quote
Old 01-28-2012, 12:18 PM   #13 (permalink)
You need to have it flushed not changed.
Old 01-28-2012, 12:35 PM   #14 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
So it was done at 86,400 miles, and now it's got 100,500 miles? Flushing should not cause any problems at all. People that say that are talking about severely neglected vehicles, like more than 100k miles with no trans oil changes.
BMR is offline   Reply With Quote
Old 01-28-2012, 12:47 PM   #15 (permalink)
Thanks for the responses. Also, the record said it was done with synthetic fluid. When I mentioned it to the service guy at jiffy lube, he said it would be $75 for the exchange and an extra $20 for the additive. Now is this "additive" referring to the fluid converter that's frowned upon or is it something else.
Alpine CDA-105 HU
