Help!!! Cant drive at night until solved - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2012, 06:16 PM   #1 (permalink)
Falloutkid90's Avatar
View Falloutkid90's Photo Gallery
3rd Generation Help!!! Cant drive at night until solved
So I installed my retrofitted headlights/hids and new corners this morning. When changing the corners, I was attaching the two wires (power and ground) and one touched another and the was a small spark and a tiny bit of smoke. Now I was driving home from work (its dark now) and I turn on my headlights worked fine but no instrument cluster lights! I cant see how fast im going or how much gas I have. I get home just now and lock my car with the remote and usually the lights flash (tail lights, corners, and instrument cluster), no flash occured. Did you guys think I blew some fuses or something?
Slow and low is the way to go
http://www.cardomain.com/ride/393487...ry-le-sedan-4d
Falloutkid90 is offline   Reply With Quote
Old 01-13-2012, 06:39 PM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Sounds like you blew a fuse...
RichieRichJP is offline   Reply With Quote
Old 01-13-2012, 07:45 PM   #3 (permalink)
Any idea which one it could be since theres 4 fuse boxes and and bunch of fuses in each. I keep reading about the tail light fuse but i dont know.
Old 01-13-2012, 08:35 PM   #4 (permalink)
View 1996camry's Photo Gallery
sound like the fuse blow...
here is how to tell a fuse blow or not blow...
look under your hood if you stand in front of the car... the two fuse box is on the right... just open and look if the filament burn, you can see the fuse wire broken half. that is how you can tell goo or bad....
also, there is another fuse box underneath your corn holder under the driver side.. you have to remove the corn holder to see the fuses.
1996camry is offline   Reply With Quote
The Following User Says Thank You to 1996camry For This Useful Post:
Falloutkid90 (01-13-2012)
Old 01-13-2012, 10:16 PM   #5 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445745
View uibalnme's Photo Gallery
+1
...and next time you do any electrical work on your car, disconnect the negative cable from the battery. it's easiest way to keep from blowing fuses or frying something.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Tags
drl, help...please, instrument cluster, no lights
