Hello, I wrote an eariler post about how to replace the EGR Valve. Someone responded with an EXCELLENT reply with pictures on how to change the EGR Valve, which has helped more that imagined. However this isnt the only problem. See the code that AUTO Zone told me was code PO401 Definition EGR system fault (Exhaust gas recirculation) The ECM has detected too little flow on the EGR Valve. Probable cause: 1.blocked passage on EGR system 2.failed EGR valve 3.EGR solenoed faulty 4.failed EGR Pressure sensor (where applicable) 5. failed EGR position sensor (where applicable) O.K. that list of five things was what Auto zone printed out for me.
Now the post I got eariler was for replacing EGR Valve. Now does anyone have a post with pictures or diagrams of how to replace the EGR soleniod???? See auto zone told me that if replacing the EGR valve didnt work, then it is probably the EGR solenoid, but i dont see any posts on here on how to change it or even where its located???
Next question is if i find a post, or someone kindly email me one, about how to change the EGR Solenoid and I do change it. If the check engine light is still on, then does anyone have a picture or easy chart on how to replace the EGR Pressure sensor or the EGR position sensor???
Please help me because i am not mechanically inclined, but however, i can follow pictures and diagrams very well, with detailed instructions.
THANK YOU ANYONE WHO CAN HELP ME!!!!!!
