94 Camry LE/4-cylinder/Low RPMs at startup
When i startup my car the RPMs are real low, around 300-500 for about 10 seconds or so. It sounds like the engine is struggling. Then it kind of kicks in and shoots up to about 1200-1500 for a second (like a normal start), then settles down at normal idle RPM of around 900. This happens about 80% of the time i start the car. The other 20% being normal starts with no problem. Very rarely it will take me a few tries to get the car started at all; most of the time the start goes as stated above.
I am wondering if anyone has an idea what this could be??
I was told at my last oil change that i need a new alternator belt, so i am wondering if maybe that has any correlation to this problem. I have had many problems with my battery cables as well, which i thought had been solved. A lot of electrical issues it seems. I am no expert by any means, so I am trying to give as much info as I can. Let me know if more is needed.
Any ideas would be appreciated. Thanks.
