Ride height - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2012, 10:37 AM   #1 (permalink)
View ctcam99's Photo Gallery
Ride height
Did a search - nothing. So My question is why ride height so high after changing stut/springs 4 corners? History '99 LE 4 cyl. 14' wheels 113xxx mi. wheels, tires, stuts/springs shot. put on 16X7 wheels and Monroe quick stuts at same time. Car sitting very high! Monroes defective, replaced with Gabriel ultra's. Struts now fine but ride hight is still very high, so much so I think it's effecting handling. Alignment done and is good.
Gotta bring it down, Lowering spring?
or what
Thanks,
Bill
ctcam99 is offline   Reply With Quote
Old 01-15-2012, 12:26 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Did you compare the old springs to the new springs? Are you sure you have the right parts on there? Maybe yer used to the old springs that now it's at the right height it seems high to you?
Measure the clearance from the bottom frame to the ground and post it.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 01-15-2012, 02:18 PM   #3 (permalink)
The old set up is gone had no reason to think there would be a problem.
Both new sets result in same height, It's way high. The inside rear trailing arm piviot is 11" from ground and the lowest point on the driver side K member (lowest part of the frame ) is 6": from ground. The front fender well is 26.5" and the rear is 27.5" up. Wish I could post pic's.
If I go with Eibach's etc. I will have bump stop problems with the stock length struts!
Old 01-15-2012, 02:18 PM   #4 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
its probably because the car was that high when you first bought it and started sagging along the years and you forgot how it sat when you first bought the car. now that you've replaced the struts, the car sits normal again and you think that its too high.
lowering springs will lower it.
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 01-15-2012, 02:50 PM   #5 (permalink)
View hodgoes2001's Photo Gallery
i Found a 3CM lowered set of Spring look great
The car will raise a bit when you put mag wheels on...
Because there is less give so to speak... with the extra bit of alloy and less rubber at a higher pressure
My Camry with the 3cm lowered springs
hodgoes2001 is offline   Reply With Quote
Old 01-15-2012, 05:41 PM   #6 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
You're in the range. Mine sits are 27.5" from ground to the top of the fender lip and 26.5 on the rear. Looks heavy and low on the back. I replaced the front with Monroe's Quick Struts and it raised the front but I though the new springs haven't settle yet. I swap the old springs in the front and it was the same thing height.
If you go with Eibach's, you shouldn't have problem with the bump stops. The spring should have the same uncompressed height as the OEM but sit lower than stock due to a different spring rate.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 01-15-2012, 06:22 PM   #7 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
^My TRD lowering springs were never the same height of the stock springs. They were physically shorter. And I compared them on the bench when I did the job way back when. Just saying.
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
