I believe the max towing weight was the same for the Gen3 and 4 Camrys - 2,000 pounds total tow weight and 200 pounds tongue weight.
You may want to take a look at how you are loading the trailer and if the actual trailer can be re-configured. Load the trailer and put the tongue jack on a scale to get the weight. You should not be exceeding the 200 pounds. The tongue weight should be between 5 and 15% of total tow weight. If it is more, you can load heavier stuff in the back. Moving the trailer axel forward will also reduce the tongue weight - this may be easier (and certainly cheaper) than replacing the car's suspension.
I'd replace all springs / struts and put in some spring spacers in the back.
Take a look at my towing thread for more useful information -
Towing with Gen 4 auto (rear shocks etc)
