Problem After Not Starting My Es300 For A Few Days.i need help!
ok let me know lay this out the best i can.i go to new york every weekend friday through tuesday.my 93 es300 sits in a bus station park and ride for those days.when i come back tuesday evening.my car hesitates to start,when it does.i put the car in drive and start to move in which she hesitates and does not accelerate normally when i hit the gas.its running but doesnt accelerate with any power. this last time i was blowing smoke out of the exhaust.after about 3-5 minutes driving around the parking lot it starts to drive again back to normal.if i drive the car everyday this doesnt happen its only when i leave the car for a few days sitting.anyone have any suggestions or experience with this problem?any and all help is much appreciated thank you
You may have a slow drip from 1 or 2 of the fuel injectors from the residual fuel pressure in the line.
When you get it started it needs to clean itself out from the over rich condition.
A combination of this and add worn valve stem seals and there you go.
Sounds like this car is calling out for some needed maintenance.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5 Cheers!
ill be honest with you guys.ive had the car 3 years and ive been leaving it at the park and ride for 3-4 days for about 2 years now.and havent had this problem till recently maybe within the last 2 months.but this recent time was the worst with the smoke coming out when i hit the gas.when i put it in drive and start to drive when i hot the gas its revving but the car doesnt take off as it should.i can press the peddle down hard and it doesnt accelerate
i know white smoke means the head gasket,but this only happens when the car sits for a few days,its never happened before and never happens when i drive day to day.and i dont notice any lack of power.
It could be leaking valve stems, fuel would be black smoke. A weeping head gasket makes sense, next time let idle for a while and then see if it takes off normally. The coolant temp sensor could also cause weird stuff like this.
