To flex or not to flex - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2012, 07:02 PM   #1 (permalink)
View ShawnD93Toy's Photo Gallery
3rd Generation To flex or not to flex
Now I know its a flex pipe on the v6, but I am getting ready to have to replace it again. I have read that the flex is there for functionality with the motor moving around, but would it be absolutely crazy to have a front pipe made out of just solid pipe? Does anyone have experience with this?
ShawnD93Toy is offline   Reply With Quote
Old 01-19-2012, 08:38 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
No experience with doing that, but it seems like a bad idea to me. The engine is mounted on rubber mounts to isolate the engine vibrations from being transmitted to the car body. Because of that, it moves a bit when it's generating acceleration/deceleration torque. The flex pipe is in there to allow that to happen. Replacing it with a rigid pipe would likely not last long; the stress generated when the engine tries to move repeatedly would likely crack it quickly.
If the flex pipe is breaking again after a short time, inspect the motor mounts. If they're broken, they can allow the engine to move too much, and break the flex pipe.
BMR is offline   Reply With Quote
Old 01-19-2012, 08:48 PM   #3 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Any solid pipe will just crack and soon. If it's too solid, it can actually crack the exhaust manifold.
Not good.
Zembonez is offline   Reply With Quote
Old 01-19-2012, 09:57 PM   #4 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
Do you really think that Toyota engineers went for the more expensive approach for no good reason?
TedL is offline   Reply With Quote
The Following User Says Thank You to TedL For This Useful Post:
projektvertx (01-19-2012)
