Need help with window motor techinical question?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2012, 08:33 PM   #1 (permalink)
98 Camry Jeff G
View jeffgent3029's Photo Gallery
3rd Generation Need help with window motor techinical question??
Ok here is the situation. My drivers door window will only roll about a quater of the way down then seems like it runs out of power and just stops. When I hold up on the window and press the button for the window to go back up, it goes about half an inch then stops. A mechainc told me that my power window motor is going out or already is bad. Well I dont have enough funds to buy a new one so here is my question
Can I use another motor from another window in my car that I know works??
Example, can I take the rear drivers side window motor out of door and put it in the drivers front door??
Example, or can I use the passenger side front window motor and just replace the one that is broke??
See my car didnt pass inspection in louisiana, and the person told me it failed because my drivers window wouldnt go down, so I need to replace it, but he said that its the only window that has to roll down to pass the inspection, so I dont mind if I loose another window rolling down, as long as my drivers side front window will work.
PLEASE HELP!!!!
jeffgent3029 is offline   Reply With Quote
Old 02-01-2012, 04:25 AM   #2 (permalink)
View travd93's Photo Gallery
I dont see why you wouldnt be able to use another roller.
What makes you think you cant?
travd93 is offline   Reply With Quote
Old 02-01-2012, 06:40 AM   #3 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
Have you even looked up the part numbers for the four different locations?
TedL is offline   Reply With Quote
Old 02-01-2012, 06:53 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
call a local salvage/junk yard and buy a used motor. if you are somewhat handy, you can probably install this yourself and save the money instead of paying someone to install it for you.
Old 02-01-2012, 08:16 AM   #5 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I would get the entire Assembly, motor / Regulator (Part with the cables connected to it).
If you just try to replace the motor, and dont know what your doing your not gonna be able to wind the cable up properly.
Tags
window motor, window regulator
