Ping, Ping, Ping sound after turning car off, possible from exhaust manifold? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2012, 11:37 PM   #1 (permalink)
View Judge2's Photo Gallery
Any ideas on what I might be facing.
After turning the car off, I get a ping, ping, ping, ping type sounds from the engine. listening with a mechanic stethoscope makes me think its coming from the exhaust manifold area.
Does this suggest something is cracked?
Judge2 is offline   Reply With Quote
Old 01-24-2012, 04:03 AM   #2 (permalink)
View matt1mzfe's Photo Gallery
If the engine is hot the exhaust manifold heas shield gets very hot and as soon as the flow of hot exhaust stops the manifold and heat shield begin to cool and contract as they do so. The thin steel heat shield cools much faster than the thick cast iron block & exhaust so it contracts much faster and moves where it is bolted on to the block making a creaking sound.
My car does this after a longish drive, I have no leak / crack... it runs perfectly. I would be very hesitant to believe a mechanic who is trying to tell you there is a problem just because of this sound when the car is turned off.
Does it sound and drive ok when turned on - if yes then don't let the mechanic fool you into paying - he will most likley take the heat shield off (a few bolts) put some high temp pearing grease on the bolts... and refit it. Then tell a story and charge you a lot.
I would be asking myself how much I trust this particular mechanic too.
matt1mzfe is offline   Reply With Quote
Old 01-24-2012, 07:14 AM   #3 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
Is this your first car? Every car I've owned in the last 25 years has made that sound. As noted above, it's from the thin metal heat shields as they cool.
TedL is offline   Reply With Quote
Old 01-24-2012, 11:28 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
second that - pinging from a hot cat when it starts to cool is normal.
Old 01-24-2012, 02:12 PM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Yup, totally normal. Every car I've ever had did it.
BMR is offline   Reply With Quote
Old 01-24-2012, 02:26 PM   #6 (permalink)
View nevada's Photo Gallery
what mechanic? he didnt say anything about that.
he said HE listened to it with a stethoscope...
nevada is offline   Reply With Quote
