P0128 - Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0401 -Insufficient EGR Flow
P0440 -Evaporative Emission Control System Malfunction
P0446 -Evaporative Emission Control System Vent Control Circuit Malfunction
The P0128 is most likely due to a bad thermostat. Replacing it should cost $20 - $30. Use a Toyota OEM thermostat or Stant with the jiggle valve.
PO440 could be the gas cap isn't sealing.
There are DIY threads addressing some of the others, but you didn't say if your car has a V6 or 4 cylinder. So look thru this list of stickied threads to see if they're covered.
