Broken alternator tension bolt..OK to drive? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2012, 08:03 PM   #1 (permalink)
View oldtruckluvr's Photo Gallery
I was tightening my alternator belt with the tensioning bolt on the alternator bracket and the head sheared off. Is it ok to drive without the tension bolt in the bracket? The main bolt that holds the alternator on is tight. It will only be for a few days until i can find another bolt and replace sheared bolt. Thanks
oldtruckluvr is offline   Reply With Quote
Old 01-24-2012, 08:58 PM   #2 (permalink)
View nevada's Photo Gallery
as long the belt is tight, it will be fine.
i drove for years with the tensioner bolt broke on my AC pump.
nevada is offline   Reply With Quote
Old 01-24-2012, 09:06 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
as long as the pivot is tight and lock bolt is holding, y7ou are good to go like that. will be a problem at next drive belts change
Old 01-24-2012, 10:20 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Yeah it's the lock bolt that hold the set tension. The jackscrew isn't going anywhere.
Besides the dealer you can find one at parts stores or maybe Home Depot. Just make sure is has threads over the entire shank, because higher strength bolts don't.
Old 01-27-2012, 06:13 PM   #5 (permalink)
thanks, put a new bolt in today!
